Home > Forums > Software User Forums > FLOW-3D
pressure can't converge with 2nd-order method
Old   December 27, 2021, 11:04
Default pressure can't converge with 2nd-order method
ZHANG H.
Unharuka is on a distinguished road
Hllo everyone,
I'm using FLOW-3D HYDRO v1.0 to do numerical simulation. However I can't open second-order in Model Setup →Numerics→order of approximation. Once I open it, the simulation will show "pressure iteration did not converge" whatever simulation I do.
I used FLOW-3D v11.2 for a long time, and it works correctly. So I don't think there are any fatal errors in my setup. It confused me for a long time. Thank you very much!!!
Unharuka is offline   Reply With Quote
Old   February 10, 2022, 08:26
Simon Armstrong
SimonBrasfort is on a distinguished road
Hello!
I have faced this issue as well and technical support at Flow-Science's technical support is aware of it. The issue should be resolved in the updated solver within FLOW-3D HYDRO 2022R1.
SimonBrasfort is offline   Reply With Quote
Pressure fields in FOAM, p field, total pressure, etc. Tobi OpenFOAM Post-Processing 9 March 25, 2022 01:33
what's faster, 2nd order eqs from the begining or 1st order and then 2nd order eqs? TimberJ3 FLUENT 0 April 1, 2014 09:08
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
