December 29, 2021, 04:54 |
How see SI unit of History Data
Sarp
Rep Power: 4 |
Hello everyone ,
I'm working on floating objects with mooring lines. I would like to see the SI units of pressure, kinetic energy ..etc at '' history data'' graph but I cant see any SI units, like for pressure kN/m^2 or for velocity m/s ... in axises. To summarize I would like to see the SI units at X-axis and Y-axis at data history graph at Flowsight program. Thanks for your help. |
December 30, 2021, 03:57 |
Rep Power: 11 |
Hi
New flowsight versions put units automatically. version 10.2 does but 10.1 do not... |
December 30, 2021, 14:48 |
Sarp
Rep Power: 4 |
I have v11.2 but I still cant see the SI units at History data graph . Maybe I did not activate it. I dont know how to see the SI units . Like unit for pressure. For example in graph we can see the value of 200 but is it kN or N ...
December 31, 2021, 04:32 |
Rep Power: 11 |
I mean ensight's version. I have f3d 11.2 and flowsight did not show units. but newer f3d versions showed. but basically units are in the same order as your simulations. units are absolute. If you use SI your units are kg, m and s. so your forces are kg*m/s2, pressures are kg/m*s2
by the way, at f3d-analyze tab there should be a "units" button at bottom right. you can graph results with units at f3d gui. |
December 31, 2021, 05:54 |
#5 | |
Sarp
Rep Power: 4 |
December 31, 2021, 06:12 |
Rep Power: 11 |
you welcome. If you have further questions feel free to ask. good luck..
December 31, 2021, 08:25 |
Sarp
Rep Power: 4 |
If ım not boring you , I would like to ask a question.
For example, I would like to see the pressure force at the surface(X-min surface) of the floating object. I have plotted History graph for X-axis for floating object . I wonder , does this graph shows the force acting on the surface of the floating object ? I tought graph shows the wave forces acting on the left side(X-min) side of the object. |
January 3, 2022, 01:56 |
Rep Power: 11 |
this graph shows x component of total pressure force acting on every surface. If the driving force comes from wave, so yes this is wave force. if your wave is normal to xmin surface so yes, effectively the graph is for xmin surface. but if object will rotate for some reason, the side surfaces will contribute to this force graph also.
I hope this is an answer for your question. If not, I may understand it wrong. |
January 3, 2022, 04:21 |
#9 |
Sarp
Rep Power: 4 |
Dear Sir, that was the exactly what I wanted to learn. Your answer was very informing. Thank you for your interest
[OpenFOAM] Paraview python script, creating data using only CLI, saving in csv/excel file | Ash Kot | ParaView | 1 | September 24, 2021 12:23 |
Grid I Unit Normal and Grid J Unit Normal | pawansut | Tecplot | 4 | July 31, 2017 18:14 |
how to caculate the mass of impacting particles per unit area and per unit time? | xyq916 | CFX | 0 | October 8, 2015 08:55 |
ã€Help】"Error: Update_Time_Level: invalid data" | Chen | FLUENT | 2 | August 24, 2014 07:51 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
