March 29, 2023, 14:51 |
Discharge coefficient
Mikolaj
Rep Power: 3 |
Hi everyone,
i'm trying to detemine discharge coefficient for simple problem - outflow of water from the large tank through small orifice. After few trials i am getting Cd=0.8. Cd=Qflow3D/Qtheoretical Any tips or suggestions ? |
March 29, 2023, 23:51 |
Sehroosh
Rep Power: 7 |
For finding out discharge coeffcient from model data, same orifice equation will work
Qmodel = Cd x A x sqrt(2gh) Qflow3D/Qtheoretical works when Qtheoretical is determined without Cd. Last edited by MSM1985; March 30, 2023 at 01:43. |
March 30, 2023, 01:57 |
Mikolaj
Rep Power: 3 |
Hi, thanks for reply.
I dont think i described the problem in detail. I am trying to calculate Cd from equation Cd=Q_flow3D/(Asqrt(2gh)). (in my mind A x sqrt(2gh) = Qtheoretical ) To get Q_flow3D and A(area) i am placing baffle (flux surface) in orifice. To get h i am placing history probe. BC Ymin,Ymax,Zmin -wall; Xmin-fluid elevation, Xmax-outflow, Zmax- fluid fraction 0 After that train of thought i am getting Cd around 0.8, i was hoping for 0,6-0,65. |
March 30, 2023, 02:09 |
Sehroosh
Rep Power: 7 |
Cd varies from 0.61 - 0.98, depending upon orifice entrance conditions
November 30, 2023, 05:23 |
Rempel Jody
How to accurately determine Cd value.
November 30, 2023, 23:35 |
Sehroosh
Rep Power: 7 |
most accurate method is physical model observations
May 6, 2024, 14:30 |
henry oven
The discharge coefficient is a dimensionless parameter used in fluid dynamics to describe the efficiency of a fluid flow through a constriction or an orifice. It represents the ratio of the actual flow rate to the theoretical maximum flow rate under the same conditions.
basketballlegends |
May 15, 2024, 12:44 |
Henry
Venturi meters and other flow measurement devices rely on the relationship between pressure drop and flow rate. The discharge coefficient is used to correct for the effects of fluid viscosity, turbulence, and other factors on the accuracy of flow measurements.
basket random |
discharge coefficient |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Nozzles: Modeling the Discharge Coefficient | LiamH | Main CFD Forum | 0 | March 12, 2014 11:41 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Discharge coefficient in function of pressure ratio | Roland R | CFX | 1 | September 24, 2012 21:58 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
