July 16, 2023, 05:10 |
Scour Geometry Simulation
Batuhan
I am a master degree student at the university. My thesis topic is “Investigation of Scour Geometry and Amount of Removed Sediment Caused by Pressure Washing of Reservoirs”. There are experiments I have done in the laboratory on this subject. You can see the experimental setup in the photo I attached. My advisor told me to solve this issue in Flow3D HYDRO as well. I created a model like the attached prepin file. The characteristics of the experimental setup are as follows; • Flow rate 9lt/sec • Pipe inner diameter (D= 0.026295m) • Pipe outer diameter (D’=0.03m) • The pipe has penetrated into the sediment by half the pipe diameter (l/D=0.5) • The axis of the pipe is 2.5 times the inner diameter of the pipe above the base (c/D=2.5) • Sediment grain diameter 0.00125m This is how I set up the model. But I can't get solution. Can someone who knows the subject help? Thanks. |
pipe, reservoir, scour, scour depth, simulation |
[ANSYS Meshing] CATIA Geometry Generation and Meshing | danielsullivan | ANSYS Meshing & Geometry | 0 | April 3, 2017 21:11 |
Best software for centrifugal fan (rotating geometry) simulation | DRoam | Main CFD Forum | 0 | November 18, 2016 16:12 |
import geometry of fliud from abaqus for FSI simulation | mina.m | STAR-CCM+ | 3 | October 31, 2013 11:32 |
[ICEM] Geometry cleaning to use a multidomain simulation | Attesz | ANSYS Meshing & Geometry | 1 | October 20, 2009 09:38 |
Export geometry in workbench from simulation. | kezman | ANSYS Meshing & Geometry | 1 | October 14, 2009 14:06 |
