Zhengming Wang
Rep Power: 0 ![]() |
Hello experts,
I'm simulating a wire DED model in Flow3D and have a problem with the wetability of the liquid on the substrate. Initially, my bead had a flat top surface with the material properties in Flow3D database. After that, I tried to activate the surface tension model and tested different contact angles (0-120 degrees). Then, the top surface changed to a convex surface. However, those simulations with different contact angles (0-120 degrees) showed almost the same bead shape. I found two parameters 'Contact Angle' and 'Contact Angle to Solid Phase' under Material>Surface Tension category in Flow3D Weld, but I don't know which one is the contact angle (theta_c) in the normal wetting case on a flat substrate. Could you give me a example about those two parameters? My Flow3D version is 12.0. Appreciate any information you can provide. Thank you in advance! |
contact angle, flow3d |
Fluent UDF Mesh Motion Issue: Blade Pitch w/ Respect to Azimuth Angle | recmvp | Fluent UDF and Scheme Programming | 0 | July 30, 2023 15:50 |
surface tension model and contact angle model | ltl | FLUENT | 0 | October 13, 2022 07:30 |
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle | FelixJJ | FLUENT | 2 | October 20, 2021 02:39 |
Contact Angle Model in OpenFOAM | chitransh_atre | OpenFOAM Running, Solving & CFD | 0 | January 20, 2021 21:41 |
About the Contact Angle | Flora | FLUENT | 2 | March 8, 2007 02:07 |
