Home > Forums > Software User Forums > FLOW-3D
Setting or Graphics problem?
Old   December 2, 2008, 11:11
Default Setting or Graphics problem?
Nikolaos
I am trying to simulate a rotating object with GMO. It is a cube which rotates (or it should rotate) around a fixed axis outside the rigid body. Imagine it like rotating a big dice with a rope. M focus is only at a 10-12 degrees arc. So, when I input the data, and I have some first results this weird thing happens: I go to the display tab, and I can see the object moving for 1-2 frames, but then it starts deforming like being cut to slices with the same direction as the motion. Thes slices move together with different speeds as it seems. May I note that the fluid seems to be flowing on the surface, but it doesn't leave any marks, it's like passing through the object. I know, it is really weird, but if you have any clue, please help me. I will try to make the video out of the simulation when it is finished and I will update you.
Thanks a lot!!
Old   December 3, 2008, 09:33
Default Re: Setting or Graphics problem?
michael barkhudarov
Have you tried 2D slices, say in the plane of rotation?
Old   December 3, 2008, 11:48
Nikolaos
It seems to be a graphics problem, something is wrong with the rendering, because I tried several videos and they all were different. It struggles to handle the stl subcomponent. If there is any solution towards this direction...otherwise I will use my patience to render each image separately and then produce the video externally.
THANKS!
Old   December 5, 2008, 00:31
michael barkhudarov
Well, if this is the hardware problem, then there is not much that can be done beyond replacing the card. So is it just slow or are the images bad?
Problem in setting porosity region for rhoPorousSimpleFoam run_cfd OpenFOAM Pre-Processing 1 May 31, 2011 09:02
[ICEM] Problem with graphics while manipulating model (frozen for some seconds) Freeman ANSYS Meshing & Geometry 4 October 17, 2009 14:35
Need help in setting up a shock tube problem kalee FLUENT 0 November 2, 2007 14:11
cfx5.7 linux graphics problem matej CFX 0 June 11, 2004 02:30
problem with setting up compiled udf sivakumar FLUENT 2 March 13, 2002 11:24
