January 7, 2009, 04:31 |
STL File Creat tools
I want to know that Which CAE Tools is the most suitable one to creat STL file for Flow 3D?
Solidworks, UG, ProE...? |
January 7, 2009, 22:33 |
Re: STL File Creat tools
ShFlow any MCAD tools such as Pro-E, Solidworks, SolidEdge, UG,...can be used to create STL files for Flow-3D. So far i didn't encounter major issue with SLT import for Flow-3D
January 8, 2009, 20:51 |
hai, i use AUTOCAD 2007 for create STL n ihave no worry bout that
January 9, 2009, 00:25 |
Thanks! Yes, I try to use Autocad to make STL for Flow3D, It seems no problem at all.
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
2.0.x on Mac OSX | niklas | OpenFOAM Installation | 74 | March 28, 2012 16:46 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 07:11 |
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 04:43 |
