Home > Forums > Software User Forums > FLOW-3D
Two fluids
Old   November 22, 2008, 15:14
Default Two fluids
Armen A. Ghirghidov
Does anyone know how can I model two fluids in FLOW-3D. Am I need two mesh blocks for them. Unfortunately I did not find anything in User Manual unusefull.
Regards, Armen
Old   November 24, 2008, 12:21
Default Re: Two fluids
HC
No, you don't have to have two mesh blocks for them. In two fluids model, fluid #1 has the fluid fraction of 1, and fluid #2 has 0. The fluid fraction between 0 and 1 means the mixture of two fluids. When you create initial fluid regions, just make sure the fluid fraction for each region is assigned with the correct value. The same applies to the boundary conditions.
Old   November 25, 2008, 06:12
Armen A. Ghirghidov
In this case when I need to include surface tension I do not know which one surface tension is on - water or oil, for example.
Old   November 27, 2008, 00:05
michael barkhudarov
Armen,
Surface tension is not a property of a fluid, rather of the interface between two media. So when you turn it on in oil-water case, it applies to the interface between oil and water.
Old   November 27, 2008, 05:57
Armen A. Ghirghidov
Thanks a lot.
two mixing compresible fluids solver ziemowitzima OpenFOAM Running, Solving & CFD 27 August 13, 2020 12:40
radiation modell with two different fluids discovolante Main CFD Forum 1 April 26, 2009 16:05
Differents fluids separated by wall phil FLUENT 0 January 18, 2007 02:43
3D-Flow: Tank with 2 fluids with no separation Juan G. CFX 0 October 4, 2005 18:38
turbulent mixing of two fluids ulrich bieder Main CFD Forum 2 October 9, 1999 16:15
