December 8, 2008, 23:27 |
Turbulent Energy TKEI
Hi All does anyone have any guideline to set the turbulent engery (TKEI) in the initial tab?
Rgds CK |
December 9, 2008, 08:57 |
Re: Turbulent Energy TKEI
I think it depends on what you are trying to represent in your simulation. Is it about a virtual wind/water-tunnel? Or a GMO moving in quiescent fluid? Or what else?
December 9, 2008, 23:02 |
Stefano it is case where GMO is moving from x+ to x- while impinge by water jet. so do you have any idea on how to set the TKEI? or do you have general guideline to set this parameter?
Rgds CK |
December 10, 2008, 11:10 |
I think that if you want to represent an object moving in quiescent/calm water, than probably the best realistic condition is to set tkei=0 (you don't have turbulence in a water that is not moving). Instead if you are representing an object invested by a fluid flow, like in a wind-tunnel, then you should set the turbulence equal to the one of the wind-tunnel (sometimes known) or leave it to the default value that is a small number, but not zero. Tell me if this helps...
question about turbulent kinetic energy | junker4236 | Main CFD Forum | 19 | April 19, 2017 04:46 |
LES and total turbulent kinetic energy | Boerge | FLUENT | 1 | September 8, 2012 11:41 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Turbulent Kinetic Energy | Olga | FLUENT | 2 | October 11, 2002 15:05 |
calculation of (turbulent) dissipation energy ? | max | Main CFD Forum | 3 | August 18, 1999 09:42 |
