Home > Forums > Software User Forums > FLOW-3D
SMP Scalling Performance
Old   February 10, 2009, 04:56
Default SMP Scalling Performance
CK
Hi All i'm currently running SMP with 4 CPUs and would like to understand if any user out there tried >4 CPUs with SMP version for actual application? and what is the scaling performance?
Old   February 10, 2009, 15:37
Default Re: SMP Scalling Performance
Melissa
Yes, and have seen up to 3.5X speed up with 8 CPU's.
Old   February 10, 2009, 18:57
CK
Melissa have you tested with actual application? what kind of physic is involved?
Old   February 11, 2009, 10:48
John Ditter
The performance of the SMP code varies depending on the models activated. We've benchmarked FLOW-3D on a dual/quad Intel Harpertown 2.8 GHz Xeon 5462 w/1600 FSB using 8 processors. All simulations continued scaling out to 8 processors and the scaling ranged from 1.3x for an axi-symmetric noozle simulation with about 150,000 cells to 3.4x for a shallow water simulation of a reservoir.
Other simulations run on 8 processors: Fuel Sloshing, isothermal, GMRES pressure solver, 2 million cells: 3.1x High Pressure Die Casting, explicit heat transfer, GMRES pressure solver: 2.85x Lost Foam Casting, implicit heat transfer, 250,000 cells, 2.63x
Old   February 11, 2009, 23:15
CK
John Thanks for inputs and feedback. But have you tried it with GMO + turbulent model? since GMO is program to run in serial so would like to understand if any benefit to run with 8 cores SMP. Thanks.
Old   February 12, 2009, 10:38
John Ditter
The GMO model is not parallelized at this time so you will not see a significant speedup when GMO is active. Turbulence will not affect the scaling however.
Old   February 12, 2009, 19:19
CK
John Thanks for the inputs and btw can you send me your SMP case study report for reference?
Old   February 13, 2009, 10:17
John Ditter
Sure, send me an email at john@flow3d.com and I'll send it to you.
parallel performance on BX900 uzawa OpenFOAM Installation 3 September 5, 2011 15:52
Linux kernel performance enhancement ConnClark OpenFOAM 0 January 17, 2011 18:18
plotting a performance curve of centrifugal Fan altano CFX 2 October 18, 2008 07:12
ANSYS CFX 10.0 Parallel Performance for Windows XP Saturn CFX 4 August 13, 2006 12:27
performance problem in P4 2Ghz Melih FLUENT 4 March 17, 2004 14:05
