Home > Forums > Software User Forums > FLOW-3D
particles model
Old   December 3, 2009, 23:50
Default particles model
Atiieh Rostami
ati_ros61 is on a distinguished road
Dear experts
I want to use the particles model. I want to add particle in the inlet after becoming steady the calculation. The particles will be injected into the computational domain in 100 seconds only.
The simple model without particle model was simulated. when the simulation is steady, I restarted model for adding particles. but I do not know how can I define the duration of injecting particles? I defined the maximum number of particle as 10,000 and rate of generation of particle is 100 per second, that after 100s we will have 10,000 particles in the domain. Some of the particles will remove from outlet, and total number of particles in domain will less than 10000 and then Flow3d will generate new particles, but I do not want generation of particles after 100 seconds.
Can I restart the model for three times or not?
How can I define, stop generation of particles after 100 seconds?
Regards
Atiieh
ati_ros61 is offline   Reply With Quote
Old   December 5, 2009, 13:22
michael barkhudarov
MuxaB is on a distinguished road
The rate can be defined as a function of time in a tabular manner, I think, since version 9.3. The input variable is ratet for the rate and tms (I think) for the time.
Do you use the gui or edit prepin directly to set it up?
Michael
MuxaB is offline   Reply With Quote
Old   December 5, 2009, 21:46
Atiieh Rostami
Dear micheal,
I use the older version and I make the input file in GUI.
Atiieh
Old   December 6, 2009, 16:03
michael barkhudarov
Originally Posted by ati_ros61 View Post
Dear micheal,
Atiieh
I don't think pre 9.3 version has a time dependent particle source rate. You can check with the Manual to make sure.
Michael
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
PDF model for two kinds of particles, possible? jiahang Main CFD Forum 0 June 1, 2009 20:20
Particles leave my domain (Discrete Particle Model) diffo FLUENT 0 March 19, 2009 11:23
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
model han Main CFD Forum 0 September 27, 2005 08:35
