October 21, 2008, 08:35 |
No sharp interface - Discharge in a pipe
Hello dear users,
I am trying to calculate a discharge in a pipe with a fixed pressure and flow. What are the best boundary conditions at the entrance section and the exit section (that is to say at the begining and at the end of the mesh)? When I impose the velocity at the begining and at the end the pressure field don't stabilize and I also get negative pressure. What is the best limit condition to impose on this problem ? Thanks for helping me. Matthieu |
October 21, 2008, 11:07 |
Re: No sharp interface - Discharge in a pipe
I assume you meant that you got pressure iteration failures by saying the pressure filed don't stabilize. For that problem, you may need to check the mesh, or increase the maximum number of iterations, or use a bigger GMRES subspace size, e.g. 15, if GMRES pressure solver is applied. You may also need to use a small initial time step.
As you used velocity boundary conditions at both inlet and outlet, there was no reference pressure given in the domain and the pressure result you got would just be gauge pressure. So a negative pressure in that case would be ok. A typical boundary set for pipe flow would be velocity/volume flow rate inlet and fixed pressure outlet (as you mentioned). |
October 21, 2008, 23:46 |
Matthieu,
Having velocity at both ends of the pipe is overspecifying the problem. This causes pressure convergence problems and unphysical pressure values. Do you get a message from the mentor about a net in/out flow in the domain? Having velocity at one end, e.g., inlet, and pressure at the other should do the trick. Michael |
October 22, 2008, 12:09 |
Thanks for your advice, I put the same simulation with the velocity at the entrance section and the continuative condition at the exit section and it is working.
Matthieu |
October 23, 2008, 09:26 |
Glad to hear this, Matthieu.
December 10, 2009, 21:18 |
Please help me
#6 | |
Yi-Lang Chen
Rep Power: 16 |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
measured pressure in the discharge pipe jumps | Jan | Main CFD Forum | 1 | October 30, 2006 07:54 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
