Home > Forums > Software User Forums > FLOW-3D
two flow heat tranfer in the simple heater
Old   December 10, 2009, 05:39
Default two flow heat tranfer in the simple heater
tian
flow1025 is on a distinguished road
Hellow, all.
I want to see a simple heater. I try to set its, but always get "failures".
I set the flow 1 is water, the flow 2 is air.
The water flow in a cupper tube, and air flow outsize.
The air doesn't mix with water.
Both they have velocity, the axis of air velocity is Z , the axis of water velocity is X.
Air temperature is higher than water.
I set one block for this system, should I?
Does someone can solve this problem ,or have better ideal and method?
Thank you.
Sorry, I have poor english.
flow1025 is offline   Reply With Quote
Old   December 31, 2009, 19:45
michael barkhudarov
MuxaB is on a distinguished road
Originally Posted by flow1025 View Post
Hellow, all.
Thank you.
Sounds reasonable. Are you resolving the tube thickness all right so that the fluids do not mix? What kind of failures do you get?
MuxaB is offline   Reply With Quote
Steadystate Incompressible Flow with Heat Transfer johanzietsman OpenFOAM Running, Solving & CFD 3 August 31, 2021 09:11
2d Heat transfer external flow Richard belcher CFX 3 November 23, 2020 16:47
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
Airpak: Problems with heat flow contour conditions Ivan de Miguel Urain FLUENT 1 November 16, 2001 09:36
