Home > Forums > Software User Forums > FLOW-3D
Pile scouring
Old   February 4, 2010, 08:47
Default Pile scouring
hans_ina is on a distinguished road
Dear All,
I should modeling scouring around cylinder pile, but i have problem with depth of sediment(soil) i cant find where the input for the depth of soil and B.C at boundaries tab for input.
thank so much!
hans_ina is offline   Reply With Quote
Old   February 4, 2010, 09:04
Armen A. Ghirghidov
Ghirghidov is on a distinguished road
That is not there. it's in the Initial for fluid 2
Ghirghidov is offline   Reply With Quote
Old   February 4, 2010, 18:47
dear Ghirghidov,
you mean fluid region? i have add fluid region and add value for suspended sedimentation but after run simulation there is no sediment elevation.
Or you mean, i have to definition for 2 fluid region?
thank you
Hans
Old   February 5, 2010, 10:47
Armen A. Ghirghidov
Dear Hans.
Yes that's exactly what I mean but in postprocessing you have to check out SS as concentration. Unfortunately you will not be able to see river bottom (for example). :-(
Old   February 5, 2010, 20:34
dear Ghirghidov,
I use F3d 9.3, i can see the sediment as packed sediment concentration and my problem now is why all sediment are uplift in all areas, not around circular piles? i use 1m/s velocity for 0.6m diameter piles. Am I wrong in boundaries?
Old   February 8, 2010, 05:22
Armen A. Ghirghidov
I am not sure that using velocity boundary is correct. I believe you have to use water level (pressure) at boundaries.
Regards.
Old   March 15, 2010, 08:58
Roland Covini
cdf_roli is on a distinguished road
Hi hans_ina
In FLOW-3D Version 9.4 you have define a componment or you input a stl-file.
Then you can edit the componment proporties to "packed sediment".
greats
CFD_roli
cdf_roli is offline   Reply With Quote
Old   April 6, 2010, 02:53
niusha pourahmadi
pourahmadiii is on a distinguished road
hi
i must medel scour around bridge can any one help me?
i need a help for using flow 3d v 9.3
pourahmadiii is offline   Reply With Quote
soil -pile arun3248 ANSYS 1 March 25, 2009 23:51
Energy pile up jxia Main CFD Forum 0 March 10, 2002 15:27
Flow from a solid pile Sugen Chetty FLUENT 2 April 26, 2001 23:24
