Home > Forums > Software User Forums > FLOW-3D
How to deal with casting two fluids?
Old   April 8, 2010, 08:45
Question How to deal with casting two fluids?
wjy
anonymous
wjy is on a distinguished road
hi everyone,
I have a problem that two fluids need to be modeled during casting, use an example to explain: suppose two tanks A and B, tank A filled with fluid AA and tank B with fluid BB, AA and BB are different melting metals, C is the mold. and now AA and BB pour into C at the same time in the same inlet with different mass flow rate, heat transfer occers amoun AA,BB and the mold, I want to see the fractions of AA and BB during the process, also the fractions of metal and air should be displayed.
I tried to use two fluids model then the air disappeared, if use one fluid model ,then how to distinguish AA and BB? Please help me,thanks very much.
I've read the description of oil spill into water gas system, it uses the different density to refer to oil with fluid#1(water), and other properties are the same, and I do not know hao to distinguish oil and water.
Do I expressed clear?
wjy is offline   Reply With Quote
Old   April 14, 2010, 09:35
michael barkhudarov
MuxaB is on a distinguished road
You cannot have two fluids and void in FLOW-3D, not with a full set of properties for each fluid. But you can get close by assigning them different densities and viscosity, using the density transport model. you will have to ignore solidification since only one set of solidification properties is available.
The two metal can be distinguished wither by density, or you can use a passive scalar to color one of them.
MuxaB is offline   Reply With Quote
Old   April 16, 2010, 01:46
ck5285 is on a distinguished road
Michael
i understand this is limitation with current version, so is there any improvement planned to included > 2 fluids + void?
ck5285 is offline   Reply With Quote
Old   April 16, 2010, 11:03
michael barkhudarov
There are no plans to implement a full capability to model two fluids plus voids with multiple sharp interfaces. There are, however, some limited two-phase, two-fluid capability within the main "one-fluid and void" approach now. You can have the "one fluid" consist of two components with different density and viscosity.
Old   April 19, 2010, 02:05
Michael
pls advice why you don't see a value to further improve/enhance the feature? I believe it will be benefit to a lot of application. the problem that mentioned here is one of them..
Old   April 21, 2010, 18:42
michael barkhudarov
Originally Posted by ck5285 View Post
Michael
Hi CK,
We are plenty busy with developments that are more urgent, more useful and are based on the current framework. Developing a two-fluid/void capability will be a major extension of the current code and we do not see sufficient demand for this kind of investment.
cast, two fluids
Continuous casting simulation problem luke.christ FLUENT 6 November 24, 2020 07:14
radiation modell with two different fluids discovolante Main CFD Forum 1 April 26, 2009 16:05
sand casting quintet Main CFD Forum 1 June 23, 2008 06:35
Differents fluids separated by wall phil FLUENT 0 January 18, 2007 02:43
How to deal with source term when using RKschemes? leaf Main CFD Forum 2 May 11, 2006 10:34
