Home > Forums > Software User Forums > FLOW-3D
Creating stl file
Old   February 12, 2011, 00:45
Default Creating stl file
Y_G
yaser geraili
Y_G is on a distinguished road
Hi everyone
How can I create a 3d solid from a topography? Is there any program to do this? Actually I created a 3d solid from tin surface by Civil 3D, but it's not accurate enough.
Y_G is offline   Reply With Quote
Old   March 8, 2011, 14:09
Default question
robert
rmawimbe is on a distinguished road
what civil prog did you use? Autocad will produce any level of accuracy that you have the coordinates for.
rmawimbe is offline   Reply With Quote
Old   March 8, 2011, 17:33
Daniel
Davahue is on a distinguished road
Tin surface is not a good option.. I would try to get the geometry wide enough in the direction you are not interested.. Flow will understand it better
Davahue is offline   Reply With Quote
Old   March 10, 2011, 07:40
Armen A. Ghirghidov
Ghirghidov is on a distinguished road
Dear yaser geraili,
I tried to use Civil but I don't like it. I use just ACAD with lisp sript. Actually I don't understand what you mean "it's not accurate enough"? You prepare surface, explode it for triangles and then extrude them. Right?
Regards.
Ghirghidov is offline   Reply With Quote
Old   March 14, 2011, 00:00
Sushilkumar is on a distinguished road
What do you want to simulate..? internal part of can or external..?
as far as you want to simulate it in flow 3D you need should not create surfaces. try creating a solid of interested domain it will be easier for you to simulate.
Sushilkumar is offline   Reply With Quote
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Creating Zones from the stl file johnchang OpenFOAM 0 June 3, 2010 08:39
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
