Home > Forums > Software User Forums > FLOW-3D
Convective flux exceed limit warning
Old   September 27, 2011, 11:07
Default Convective flux exceed limit warning
quemmo is on a distinguished road
Hello everyone !
I am studying flows in fuel tank pipes. I already ran smulations with several pipe designs, and the simulation went well, no warnings and errors. Moreover, the simulations represented quite well the reality. But, i have got problems with other pipe designs. As soon as i run the simulations, i have a convective flux exceed limit warning. And the simulations don't represent the reality at all. Yet, i use the same parameters, the same blocks meshes, the same boundary conditions...The designs change a little bit : the nozzle slopes more than the previous.
So here is my question : can a convective flux exceed limit warning modify the flow significantly ?
Thanks
quemmo is offline   Reply With Quote
Old   October 5, 2011, 11:57
Jeff Burnham
JBurnham is on a distinguished road
No, convective flux warnings only alert you that the time step is being reduced, and the cycle runs again. Convective flux warnings do not affect accuracy. There's probably something else going on.
JBurnham is offline   Reply With Quote
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
Warning 097- AB Siemens 6 November 15, 2004 04:41
