Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Solidification
Like Tree2Likes
  • 1 Post By ambrish4u
  • 1 Post By lucky_m_m
Old   April 15, 2013, 06:25
Exclamation Solidification
rocky
ambrish4u is on a distinguished road
Hi....
I am working on solidification in continuous casting process.
I have got the proper contours of temperature and liquid fraction, but the problem is coming on getting the graph between the solid shell thickness vs distance from meniscus(similar graph is attached).
Solid shell thickness means liquid fraction less than 0.3.
Pls help me, i am not able to get it from a long time....
Thanks in advance.
ambrish4u is offline   Reply With Quote
Old   May 28, 2013, 06:15
Default hello ambrish4u
ahmed hasan
ah_j is on a distinguished road
hello ambrish4u ... which software u r using for this simulation i mean modelling meshing and analysis
ah_j is offline   Reply With Quote
Old   May 28, 2013, 07:58
rocky
@ah_j
hi, i m using ansys-fluent for simulation but for modelling and meshing i m using gambit.
ah_j likes this.
Old   May 30, 2013, 06:28
ahmed hasan
thank you for reply my friend,,, i am using icem cfd but i have problem with interfaces between two domains ( air and solid) and my project scope to find thickness of metal strip after solidification and find the process parameters on that thickness >>> and also thermal analysis of process >>> so how can i do that i mean which software have ability to do all that >>>> thanks in advance .... my greetings
Old   May 30, 2013, 08:54
rocky
dear ah_j
I dont have much knowledge of icem but as much i know, you can solve your problem on icem as well as on fluent. so if u are using icem then continue with that only and also have search on the forum you will definitely get some relevant information.
Old   June 4, 2013, 04:57
Smile @ambrish4u
Lynn
lynn is on a distinguished road
Dear ambrish4u, i am also working on solidification in continuous casting process. My model is 3D, but hard to converge. So i want to know how you define your boundary and improve the convergence. Many thanks.
lynn is offline   Reply With Quote
Old   July 11, 2013, 22:25
Nara Shikamaru
shikamaru is on a distinguished road
I don't get your problem. I have done similar graphs (the one you attached) to verify the FLUENT solidification model works. Just take the top point as meniscus (assuming thats the star your domain or start of steel phase) as 0 point and change the X-axis values accordingly. Take the contour curve of 0.3 liquid fraction and use that as Y-axis values (shell thickness).
shikamaru is offline   Reply With Quote
Old   March 4, 2014, 06:56
nyalkaran
pdgoyani is on a distinguished road
hello all,
i am doing solidification analysis of Sand casting mold box along with casting (complete assembly). my model is 3D and i have given all the boundary and cell zone conditions, but i am not getting the proper simulation.. my Temperature v/s time graph is exact straight line....
and i also dont know how to add energy source term in cell zone condition..
plz help me on this..
thank you
pdgoyani is offline   Reply With Quote
Old   March 12, 2014, 03:16
Default solidification in steady state
saurabh mangal
lucky_m_m is on a distinguished road
HI all,
I am currently working in continous casting problem at steady state using fluent software. I am not able to converge the solution. My model also includes pull velocity. It seems that many people have got the solution. Can you guys tell me the solver, boundary conditions and discretization schemes??
irancell340 likes this.
lucky_m_m is offline   Reply With Quote
Old   November 20, 2014, 15:48
salman
irancell340 is on a distinguished road
Originally Posted by lucky_m_m View Post
HI all,
hi
I have same problem too. if you can solve this problem, please send me your solve... please help me...
irancell340 is offline   Reply With Quote
tracking the solidification front Kuba FLUENT 1 May 25, 2018 03:06
solidification and melting mojtaba-azadi FLUENT 2 November 30, 2011 10:27
About the solidification? H.P.LIU Phoenics 1 December 1, 2010 09:49
Restart a solidification with previous solidifation data in v9.4 jk75 FLOW-3D 2 August 28, 2010 21:40
Restart for Solidification atulverma FLOW-3D 3 May 6, 2009 17:40
