solid-solid-liquid three phase flow in stirred tank |
Manjunath
Rep Power: 13 ![]() |
I am trying to simulate solid-liquid flows in a stirred tank. I was able to set up and simulate the case for two phase solid-liquid flow, 100 micrometer diameter solid particles (VF = 0.1) in water using both Mixture and Eulerian model. I am interested in adding particles of different diameter (1000 micrometer dia, VF = 0.1) to the tank, essentially creating a three phase solid-solid-liquid flow. I am getting divergence error if I solve for the volume fraction equations, even if I start with a converged initial solution which is obtained by ignoring the volume fraction equations. I am using MRF technique to model the impeller rotation and using mixture turbulence model. Any help on this issue is appreciated. Thanks, Manjunath |
Divergence after change in mass flow rate in two phase flow | meetsunilkale | FLUENT | 1 | March 25, 2013 03:03 |
Two phase flow with condensation | Sunnie | FLUENT | 0 | May 31, 2009 10:02 |
What is the difference between liquid reactive flow and gas reactive flow? | James | Main CFD Forum | 6 | May 15, 2009 12:14 |
Multiphase flow problem | icedou | FLUENT | 6 | July 10, 2005 02:52 |
Flow patterns in a stirred tank | Glenn Price | Main CFD Forum | 13 | March 20, 1999 10:16 |
