Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Divergence detected in AMG Solver: x momentum in Fluent multiphase model
Old   April 5, 2018, 19:50
Post Divergence detected in AMG Solver: x momentum in Fluent multiphase model
Adnan Shahariar
adnanshahariar is on a distinguished road
Hello everyone,
I am working on a 2D problem of jet impingement cooling. machining. In this problem, water jet is applying on the hot rectangular surface through a nozzle. The temperature of the hot surface is 700 Kelvin. I am using the mixture option in the multiphase model. But when I increase the inlet jet velocity more than 0.5 m/s then divergence occurs in momentum.
I have reduced the URF values. But the problem persists. I have tried mesh repair and improvement commands but the problem persists. I have also tried it with K-omega model but the problem continues to exist.
I have tried with all triangles and multizone quad-tri mesh with body sizing. Inflation was also done.
Last edited by adnanshahariar; April 5, 2018 at 20:01. Reason: There are some errors
adnanshahariar is offline   Reply With Quote
divergence amg solver, momentum equation, multiphase flow, velocity component
AMG solver divergence; Mike FLUENT 17 December 14, 2015 13:01
Divergence detected in AMG solver : epsilion maheshbabu FLUENT 0 April 4, 2014 05:54
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
Divergence detected in AMG solver tiankongasd FLUENT 2 March 28, 2013 12:34
Error: Divergence detected in AMG solver: x-momentum/ epsilon/ temperature bubuchacha FLUENT 6 February 26, 2013 03:30
