Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Problem with results in 2 phase flow (airstream+rain drops) over s809 wing using DPM
Old   September 1, 2013, 16:42
Default Problem with results in 2 phase flow (airstream+rain drops) over s809 wing using DPM
yoooodarulez's Avatar
Nick
yoooodarulez is on a distinguished road
Hello everybody.It seems i am having problems with some of my results concerning the 2phase flow of raindrops-airstream over a s809 wing.I am supposed to get increased drag and reduced lift,compared to the one phase flow (airflow) over the wing,and i do so for most of my AoA tested except for 2 of them,namely 5 and 14.I did some experimenting on the distance of the plane that injects the particles (surface injection) and i got some other 2 problematic angles of attack instead.I also changed the flowrate with not that much of a different result.In the problematic AoA i can see,in particle tracking,that there are no splashes in the upper part of the airfoil or not as many as in the other angles.Any suggestions?
yoooodarulez is offline   Reply With Quote
Problem on boundry of two phase flow youngan CFX 0 June 30, 2003 02:32
Problem on boundry of two phase flow youngan CFX 2 June 30, 2003 02:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Help - Two Phase Flow - Convergence Problem R.Sureshkumar Main CFD Forum 1 February 22, 2000 03:24
Simulation of Two Phase Fluid Flow Problem Using Fluent 5.0 Mohammad Al-Shannag Main CFD Forum 1 July 16, 1999 11:28
