2D VOF Droplet evaporation model. Multi-component problem |
February 28, 2014, 10:36 |
Nick
Rep Power: 12 |
I am using Fluent 14 for a 2D VOF simulation, modelling a droplet impact on a heated surface. I consider the domain to be a cylinder which contains air. The temperature of the air and the cylinder base are equal. The droplet is a solution of a polymer dissolved in water. It enters the system at ambient temperature and as it falls, the water component starts to evaporate. The droplet impacts the cylinder base and spreads; it continues to evaporate whilst on the surface. The droplet solution has been added to the initial mesh using a region adaption. I need to account for water evaporation from the droplet due to heat transfer between the droplet and air and the air and the cylinder base. I have simulated the impact without mass and heat transfer to date. Attached is a jpeg showing the domain with a droplet of the solution. Please see 'Annotated droplet phase image.jpg' So could anyone tell me how to account for the droplet containing 2 components (water and polymer) in order to model evaporation of water from the solution? If you need any more information please ask. Regards Nick |
droplet, evaporation, fluent, heat and mass transfer, vof |
How to study pressure drop of continous phase in VOF model | sajeesh | FLUENT | 4 | February 5, 2014 22:01 |
UDF: how to identify interface in VOF model | process.abhi | Fluent UDF and Scheme Programming | 1 | April 19, 2012 02:11 |
question about Heat transfer between two phases with VOF model | sooroo3 | FLUENT | 0 | February 15, 2011 03:24 |
problem with vof model | nadav wetzler | FLUENT | 1 | February 26, 2008 02:09 |
