Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Free surface flow in Ansys Fluent
Like Tree3Likes
  • 1 Post By Tanjina
  • 2 Post By mjgraf
Old   June 3, 2013, 16:05
Default Free surface flow in Ansys Fluent
Tanjina Afrin
Tanjina is on a distinguished road
HI all,
Can anyone tell me from where I can find some tutorials about free surface flow /2 phase flow(water-air) done by Ansys Fluent v14.0 ? Thanks in advance.
renzo.ml likes this.
Tanjina is offline   Reply With Quote
Old   June 3, 2013, 22:15
mjgraf is on a distinguished road
for CFX this is in the Tutorial documentation.
Fluent has something similar....
User's Guide, 26.3.2 Modeling Open Channel Flows
took about 15 seconds in the Help system. If you need more, Ansys support does pretty good.
Originally Posted by Tanjina View Post
HI all,
mjgraf is offline   Reply With Quote
Old   June 3, 2013, 22:38
Tanjina Afrin
Hello. Thanks for your help. Did you mean " Free surface flow over a bump"( tutorial 9) in CFX? because I couldn't find any 26.3 unfortunately . Would you be please more specific about the path? I am really sorry for inconvenience.
Old   June 4, 2013, 06:46
Open Ansys 14.0 Help
Search Tab
Check :: Only Search Selected Books
Select Fluent
search string :: "free surface"
keep the quotes!
Click Search
first hit should be 26.3.2
If not, the information is there, in the help.
Tanjina and Soumyabrata like this.
Old   June 4, 2013, 09:47
Tanjina Afrin
Thanks!!! Found it Finally...... I will try to do this ..Thanks again. Hopefully this will help.
Old   June 22, 2013, 14:11
Soumyabrata is on a distinguished road
Search Tab
Select Fluent
keep the quotes!
Click Search
thnx a lot
Soumyabrata is offline   Reply With Quote
Old   November 6, 2013, 12:03
Dimitris Romanas
Volumeoffluid is on a distinguished road
hi,
i have the same problem...so did you use different meshes??(one mesh for water, one for air)...because with the same mesh, fluent cannot recognize the two phases.
Volumeoffluid is offline   Reply With Quote
Old   November 6, 2013, 12:07
Tanjina Afrin
Originally Posted by Volumeoffluid View Post
hi,
Hi Volumeoffluid,
I am not clear about your problem. Finally, I didn't work with Open channel flow, but with pipe flow. And it was 2 phase flow. So I hope I may be able to help you a bit if I know the problem of yours.
Regards,
Tanjina
Old   November 6, 2013, 12:13
Dimitris Romanas
Hi Volumeoffluid,
Regards,
Tanjina
thank you Tanjina! So it will be easy if i had your email. I would tell exactly my case.
My email is jimromanas@hotmail.com
Old   November 6, 2013, 12:14
Dimitris Romanas
Hi Volumeoffluid,
Regards,
Tanjina
Also you can check my previous thread:
http://www.cfd-online.com/Forums/flu...tml#post460844
Old   November 11, 2013, 10:47
Dimitris Romanas
This is my problem
I want air in bubble and water to the the other surface, but with VOF model
cannot understand the the line between air-water
Old   April 16, 2014, 11:52
anesmath
anesmath is on a distinguished road
HI all,
I have an open channel flow and I fractionale the inlet surface to be able to to introduce the air and the water. I use the VOF model but in results, I have a problem in density! The Fluent make it all as water or air and not both! Can you hekp me please? Even with tutorials! Thanks a lot
anesmath is offline   Reply With Quote
free surface flow, two phase flow, water-air
CFX gravity driven free surface flow tutorial mechovator CFX 37 July 27, 2009 10:28
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 18:13
Free surface vortex flow Guillaume CFX 3 August 25, 2005 20:52
Free surface channel flow in Fluent 6 Tiberiu FLUENT 2 February 6, 2005 03:41
SLAW, SWIFT, and XYZFS Free Surface flow David willis Main CFD Forum 0 April 10, 2000 00:22
