April 29, 2014, 10:19 |
Problems in water-air flow simulation
Ye Bai
Rep Power: 12 |
I am trying to simulate the two-phase flow in Ansys Fluent. But the error message always shows up when I try to run the calculation. The error message is '# Divergence detected in AMG solver: mp-x-momentum -> Decreasing coarsening group size! # Divergence detected in AMG solver: mp-x-momentum -> Increasing relaxation sweeps! # Divergence detected in AMG solver: pressure correction -> Turning off correction scaling! # Divergence detected in AMG solver: pressure correction -> Increasing relaxation sweeps! Error: Divergence detected in AMG solver: pressure correction Error Object: #f' The model in my simulation is a simple one. The flow area is 2D, axis-symmetric and rectangular. The air and water come in from the top and come out from the bottom. Eulerian model and k-e model is applied in my simulation. Could anyone give me some suggestion? Thanks in advance! |
April 29, 2014, 15:06 |
Ye Bai
Rep Power: 12 |
Hi, I have changed the geometry into full region instead of axis-symmetric and the error message never shows up again. I am so confused since I used the same parameters!! Could anyone explain this?
April 29, 2014, 15:12 |
Ye Bai
Rep Power: 12 |
And I also find something weird. In the axis-symmetric model, when I choose compute from outlet in the solution initialization, the value of gauge pressure is '-1.#IND'. Is this the reason for the problem? I don't know why since I have set the boundary condition for the outlet (it is pressure-outlet).
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
question about simulation of falling water film | mengyue1 | FLUENT | 2 | March 30, 2014 10:16 |
Air flow simulation in volume with fan and opening | koziymf | FLUENT | 0 | November 14, 2011 17:44 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
