June 21, 2014, 04:47 |
Iso-clip time step updating
Rep Power: 11 |
I am simulating a water droplet movement along an inclined plane. I am using VOF model for this. To get some results, I need to know XY plot of droplet velocity and position depending of flow time. There is a possibility to export data and analyze frame-after-frame and find out the velocity, but I consider this option to be quite lengthy. What I intended to do was creating an Iso-clip surface, of volume fraction from 0.5 to 1. Then I created a Surface monitor, showing an Average of vertex values and Maximum X-coordinate within the Iso-clip surface. The problem is, that while the droplet moves, the Iso-clip stays the same (maximum mesh X-coordinate is not changing). So what I need to do is make Fluent to update created Iso-clip every time step. Is that possible? Or, is there any different way to find out the velocity and position of droplet? Thank you for your replies, Have a nice day! |
June 22, 2014, 02:40 |
Rep Power: 11 |
So I am going to answer by myself. I defined a Macro in /Calculation activities/Execute commands which computes an Iso-clip surface every time step. It seems to be working right yet.
iso-clip, surface monitor, vof |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Rapidly decreasing deltaT for interDyMFoam | chrisb2244 | OpenFOAM Running, Solving & CFD | 3 | July 1, 2014 16:40 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 09:20 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 04:35 |
