Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Operating density (UDF?) multiphase problem
Like Tree5Likes
  • 5 Post By GM_XIII
Old   April 22, 2014, 07:04
Default Operating density (UDF?) multiphase problem
David
GM_XIII is on a distinguished road
Hi all,
I am trying to model a multiphase flow clearly dominated by floatability and it clearly depends on the operating density specified. I've read some say is better to set it to the density of the lightest phase but that doesn't seem accurate to my problem. So i would like to model it with a UDF, is this possible? I think no.
note: i am suing the mixture model
Thanks in advance for your opinion
GM_XIII is offline   Reply With Quote
Old   July 10, 2014, 07:11
David
It's been some time but if someone has similar issues. The best for me was setting the reference density to 0. When you activate gravity, your pressure boundary conditions are P(BC)=Ptotal-Preference-rho0(reference density)*g*z(of the face centroid). So in order to define a constant gauge pressure the best practice is to set reference density to 0. Fluent does the above described becouse of roundoff errors, take it in count.
Regards
UDF for coal combustion in multiphase flow niisha24 Fluent UDF and Scheme Programming 13 September 19, 2022 04:01
A problem about 'printf' and 'Message' in UDF. LICH Fluent UDF and Scheme Programming 2 May 2, 2013 02:45
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls david39 OpenFOAM Running, Solving & CFD 6 January 18, 2011 11:49
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
the problem of C_R_G in UDF may FLUENT 0 August 19, 2007 21:07
