Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
UDF species transport
Old   February 2, 2021, 18:26
Default UDF species transport
qntldoql
qntldoql is on a distinguished road
Hello, I am currently building a frost model and I wanted to clarify few things. (I have read fluent theory, user and UDF guides and could not find the answers).
First of all, I currently have a species transport set up for the phase 1 (humid air = water vapor + dry air). (phase 2 = ice droplets)
If I only able species transport model, and disable reaction in the materials as well as does not select volumetric reaction + options, etc. Would the equation still be applied? (One with the diffusivity term)
d/dt (rho^q alpha^q y^q) + grad( rho^q alpha^q v_bar^q, y^q) = - grad (alpha^q J^q) + S +R + HR .
(Basically, I want R = HR = 0 and implement the source term S via UDF)
Secondly, how do I apply a UDF source term into the species transport equation. From what I gather, its from Cell zone condition > phase 1 > h20 (for my case). Would it be something else? or is this correct?
Lastly, when designing UDF for a source term.
For example, I have a source term for the momentum equation based on the mass transfer UDF.
S_momentum = -mlg*u_air
where mlg = mass transfer rate.
but the source term UDF is:
DEFINE_SOURCE(S_momentum,c,t,sd,eq)
From my understanding, C_U(c,t) would be calling for velocity of the entire thread, including ice + humid air.
To only call for the velocity of air, I have used a global parameter
thread* index_air;
and set it equal to the
Thread* air = THREAD_SUB_THREAD(thread, from_phase_index);
from the mass transfer section UDF.
And called the velocity via C_U(c,index_air);
Does this work as how I have intended in FLUENT?
I apologize in for the bombardment of questions and thank you in advance.
qntldoql is offline   Reply With Quote
Old   June 5, 2021, 22:25
sunil kumar
ksunil is on a distinguished road
Hi qntldoql,
I am also looking for a similar problem in which moist air and water droplets enter the large domain from the inlet source cells.
could you find a solution to this problem?
Thank you
ksunil is offline   Reply With Quote
UDF for Sorption in Species Transport through Porous Medium Kosch Fluent UDF and Scheme Programming 6 October 21, 2020 17:46
Moisture diffusion by species transport between air and porous desiccants jas123 FLUENT 1 April 14, 2019 13:51
Please help!! Patch and Species transport Julie FLUENT 5 August 3, 2016 03:10
A question about species box of species transport model tjushang FLUENT 2 June 25, 2014 07:56
user defined scalar vs species transport gvj_mech FLUENT 0 March 27, 2014 14:33
