phase change with multiphase flow in porous media |
September 11, 2014, 06:18 |
Hello everyone,
I'm presently on a problem I really don't know how to face with fluent : I'm working on the dissociation of a solid into gas + liquid (water and methane) inside a porous media (sand) filled with a liquid (water). I think I reviewed most of the possibilities for multiphase flow solutions proposed by ANSYS FLUENT but could not find something which can manage this phase change. Does someone know what I could do ? Can I still plan doing it using FLUENT (if you have a tutorial on a resembling problem I would be very glad) or should I use an other software/code ? Your help would be very helpful ! Thanks in advance |
February 10, 2018, 05:28 |
Max
I am working on a similar problem. Have you found a solution by now and is it possible to solve the problem with Fluent? Best regards Max |
multiphase, phase change, porous media |
How to model granular flow through porous media | Axius | FLUENT | 2 | August 7, 2014 10:34 |
Flow parallel to porous media | HannesVV | CFX | 1 | June 29, 2013 07:28 |
Porous Media coupled with internal flow | Samuel Andrade | FLUENT | 2 | August 26, 2012 09:43 |
Two phase flow through porous media | cshah4u | ANSYS | 0 | June 22, 2010 07:05 |
Discrete phase model in porous media | Pradeep | FLUENT | 0 | February 3, 2006 16:30 |
