October 25, 2014, 01:01 |
Divergence in Two phase flow.
I am trying to solve a two phase flow with air as the primary phase and inert particles as secondary dispersed phase using Fluent DPM model. The dipersed phase is well below 10% volume fraction required for DPM simulation.
I am not able to converge the solution. I am getting the following error: temperature limited to 5000 k in #no. of cells. After certain no. of iterations the solutions diverges and blows up. I have used CFL =.1 and DPM urf=.01, but still the solution diverges after initial iterations Though I have noticed that if I switch off turbulence model ( k-w SST in this case) then the model reaches convergence. Its a steady state simulation. Please help me regarding convergence !! |
divergence, dpm fluent, multiphase steady, turbulence |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Two Phase Darcy flow with gravity -> problem | Cyp | OpenFOAM Programming & Development | 0 | November 17, 2010 07:58 |
two phase flow + ice phase and breaking | soeren87 | OpenFOAM Running, Solving & CFD | 0 | September 19, 2010 10:20 |
Validation for laminar Disperse phase flow | shashwat | Main CFD Forum | 0 | April 4, 2008 02:20 |
low speed compressible two phase flow?? | cat | CFX | 0 | November 15, 2005 07:59 |
