January 21, 2015, 14:12 |
lift coefficient in phase interaction
Amin
Rep Power: 14 |
hi friends
i have a question about multiphase modeling by using Eulerian model, in "phase interaction" tab, we need to choose a coefficient for lift of phases! I'm working on a bubbly flow column and for this which model do you suggest to me? |
February 11, 2015, 20:25 |
Ngô Ích Sơn
Rep Power: 16 |
Dear,
The interphase drag model is one of the most important thing in Euler-Euler two-fluid model. In my experience, the most common drag model for fluidized beds is Gidaspow. However, you could try other models such as EMMS (Wang & Li), structure-dependence drag (Huilin), or filtered drag (Sarkar). Those drag models are not available in Fluent, thus you should use UDF for that. For dense fluidized beds and solid capacity > 0.2 of reactor volume, the Gidaspow is the best. For lean fluidized beds such as riser zone, the gas-solid structure will be affected by meso-structure of flow, the EMMS and Structure-dependence drag models are better. I did not try the filtered drag by Sarkar, but after talking with him we found the almost same solution for meso-scale interaction. |
lift coefficient in phase interaction | amin.z | FLUENT | 1 | January 25, 2015 09:33 |
Lift Coefficient CFX | david1702 | CFX | 3 | April 17, 2012 01:08 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Help needed - lift coefficient on front/rear axle | Jan Jagrik | FLUENT | 0 | September 21, 2000 10:21 |
Highest lift coefficient | Mark Render | Main CFD Forum | 5 | March 2, 2000 08:30 |
