Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
interface between molten metal and air
Old   April 26, 2015, 15:18
Default interface between molten metal and air
HBarati
hb12 is on a distinguished road
Hi everyone,
I try to model movement of molten steel free surface. When I use surface tension value greater than ~0.04 N/m, velocity increases to very high and non-physical values and also velocity magnitude in the bulk decreases too much.
it should be mentioned that when water surface tension is used, results are reasonable.
do you have any advice for this case?
hb12 is offline   Reply With Quote
Old   April 29, 2015, 06:17
Paritosh Vasava
vasava will become famous soon enough
You may want want to check the location of the reference pressure. Chose the point which is all the time occupied by the lighter phase.
vasava is offline   Reply With Quote
molten metal, surface tension, vof model
VOF simulate interface motion during evaporation ellen peng FLUENT 1 February 11, 2021 06:58
Heat transfer problem at fluid-solid interface kiwikiwi FLUENT 4 January 14, 2013 18:47
radiation of molton liquid metal in enclosure richard CFX 0 April 8, 2008 15:43
Model flow over / through expanded metal walkways. andy2o CFX 5 January 11, 2008 04:13
Metal queching with air + water mist LW FLUENT 0 January 12, 2000 13:08
