Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
reverse flow occur while activating open channel flow boundary?
Old   April 11, 2015, 16:34
Default reverse flow occur while activating open channel flow boundary?
mariam.sara is on a distinguished road
Hello I have a real problem with open channel flow reverse flow still occur while using open channel flow boundary i tried transient and I patch the water region volume fraction with 1 but how i overcome reverse flow problem I really need help with it?
mariam.sara is offline   Reply With Quote
Old   April 15, 2015, 07:07
Cees Haringa
CeesH is on a distinguished road
Hi, why is backflow an issue? can it not just be a physical phenomenon in this case?
CeesH is offline   Reply With Quote
Old   April 15, 2015, 07:23
Hi you mean backflow will not effect the results? currently the velocity results not acceptable with that obtained from literature?
Old   April 15, 2015, 07:35
Cees Haringa
backflow may or may not be a physical phenomenon. it certainly isn't an error. It could be physical, if for example the outlet is located in a re-circulation zone after some obstacle. Or it may not be, as it seems to be in your case if the velocity results are not in line with literature. But in that case, backflow is a symptom, not the cause I'd say. It could be mesh refinement helps, or maybe the turbulence model you are using (if any) is not applicable for the current simulation. Can you provide some images of the results maybe, so we can see where the problems occur?
Best,
Cees
Old   April 21, 2015, 15:15
Hello sorry if i late with respond because I am busy with exams. I have a simple geometry 2D channel and no turbulence model is used its laminar flow. My problem in brief I have stratified two phase Air-Water flow the air in top and water in bottom i used currently open channel flow boundary to find velocity distribution on both phases. I do not understand what kind of images you ask me to post?
Old   April 25, 2015, 11:27
Cees Haringa
mesh and velocity vectors would help I think
Old   April 25, 2015, 14:30
I do not think there is any problem with mesh I check skweness factor its nearly 0.013 and aspect ratio is good too nearly 1.4?
Old   April 26, 2015, 07:24
Cees Haringa
Nope, but I don't really care about the mesh quality. I want to see what the domain looks like to judge if the backflow is physical or artificial
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Open Channel Boundary Conditions Issues Env FLUENT 8 June 28, 2016 16:05
CFX Reverse flow problem even if open boundary used AdhavRohit CFX 2 December 5, 2013 16:01
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
