April 26, 2015, 15:18 |
interface between molten metal and air
HBarati
Rep Power: 11 |
Hi everyone,
I try to model movement of molten steel free surface. When I use surface tension value greater than ~0.04 N/m, velocity increases to very high and non-physical values and also velocity magnitude in the bulk decreases too much. it should be mentioned that when water surface tension is used, results are reasonable. do you have any advice for this case? |
April 29, 2015, 06:17 |
Paritosh Vasava
Rep Power: 22 |
You may want want to check the location of the reference pressure. Chose the point which is all the time occupied by the lighter phase.
molten metal, surface tension, vof model |
VOF simulate interface motion during evaporation | ellen peng | FLUENT | 1 | February 11, 2021 06:58 |
Heat transfer problem at fluid-solid interface | kiwikiwi | FLUENT | 4 | January 14, 2013 18:47 |
radiation of molton liquid metal in enclosure | richard | CFX | 0 | April 8, 2008 15:43 |
Model flow over / through expanded metal walkways. | andy2o | CFX | 5 | January 11, 2008 04:13 |
Metal queching with air + water mist | LW | FLUENT | 0 | January 12, 2000 13:08 |
