Separated flow and multiphase in the same analysis? |
July 24, 2015, 14:07 |
Ignacio
Hi everyone!
I'm new at setting multiphase cases. I'm trying to simulate a pipe with a water-vapor mixture on the inside and any gas (air, co2) on the outside. A similar case would be a double pipe heat exchanger. It's important to say that there's no mass exchange, they are separated domains (zones). The problem is that when I define the multiphase water-vapor mixture, I'm allowed only to use that mixture for all the fluids in the cell zone settings, excluding my precious cover gas. Thank you in advance! |
July 31, 2015, 10:35 |
Cees Haringa
Split the domain in 2 zones in your meshing editor, using a named selection to specify each zone. Then, you can set conditions separately for each zone under 'cell zone conditions' in FLUENT
Best, Cees |
July 31, 2015, 13:36 |
Ignacio
Thank you CeesH, but splitting the model into 2 or more zones won't help. As we did a little research, came up with this:
http://www.sciencedirect.com/science...17931012008174 The author states that "As stated in the FLUENT user’s guide, in modelling heat transfer in two separated fluid regions involving multispecies, only a single mixture material for the entire domain can be used." [3. Solution procedures - pg. 713] |
materials, multiphase, separted domains |
Calculating mass flow rate at multiphase flows | Kuslo187 | OpenFOAM Post-Processing | 1 | August 21, 2015 18:11 |
Difference in flow distribution of single phase and multiphase analysis | shivasluzz | CFX | 0 | April 22, 2015 22:54 |
Fluent v15 multiphase flow b.c. failure Non-channel flow | mickjazz | Fluent Multiphase | 1 | September 22, 2014 06:41 |
Some quiestions on multiphase flow | fjalil | CFX | 4 | June 17, 2009 12:32 |
Multiphase flow modeling | Paul | CFX | 2 | August 11, 2003 09:41 |
