Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
How to calculate particle mass flow rate in domain with respect to injection flowrate
Old   January 27, 2016, 19:40
Default How to calculate particle mass flow rate in domain with respect to injection flowrate
Jeeloong is on a distinguished road
Hi all,
I am currently specifying let say (orifice injection at a location) of 0.001945 kg/s.
Ok I know that if my simulation is transient (eg timestep 1e-6 s) which mean that the injection at respective timestep is a fraction of the total mass flow rate per unit time(s).
One thing I am puzzled that how do I calculate if the dpm injection has balanced with breakup/separation/film stripping/atomization etc.
I mean in terms of continuum airflow, I can easily calculate the mass flow rate of inlet and outlet with very small mass flow imbalance of let say 1e-10 kg/s.
How do I do that with DPM. I know that if I got Eulerian Wall Film activated. If I monitor the sum of film mass, it should tends to same solution independent of time as it converge.
Is there a mechanisms to monitor the balance? Hope you all get what I mean.
Thanks
Jee
Jeeloong is offline   Reply With Quote
How to calculate particle mass flow rate at outlet Randy FLUENT 6 April 29, 2020 13:47
cavitatingFoam: calculate the mass flow rate in a specific area sylv20 OpenFOAM Post-Processing 4 September 30, 2015 05:36
Mass flow rate boundary condition with negative values ashtonJ CFX 3 November 26, 2014 05:21
DEM - Post Processing : Particle Mass Flow Rate yesaswi92 STAR-CCM+ 4 August 27, 2014 15:23
DPM injection mass flow rate kingpots ANSYS 0 November 22, 2012 11:12
