Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Multiphase flw of nanofluids - low Nu problem
Old   October 30, 2015, 02:31
Default Multiphase flw of nanofluids - low Nu problem
Aarthy Meena's Avatar
Aarthy Meena
Aarthy Meena is on a distinguished road
Hello Everyone,
Am Aarthy, I am new to FLUENT.
I am modelling 2-D flow and heat transfer of nanofluids around an unconfined square cylinder for my M.Tech project. Initially, I tried a single phase flow using effective property models for properties of nanofluids. Those simualtions are fine and gave comparable results with the literature.
Now, I am trying to use multi-phase flow model. I am trying with mixture model in FLUENT. I tried with particle volume fraction as 0 (i.e., pure basefluid), and I got good values of Nu and drag coefficients which matched with literature.
When I increased the particle volume fraction, the values of Nu and C_D decreased. But, it is well known that, when particle volume fraction is increased, C_D and Nu will increase.
So I am stuck with this. Kindly, pls help me very urgent....
Aarthy Meena is offline   Reply With Quote
Old   October 31, 2015, 12:03
kbaker's Avatar
Khalid Baker
kbaker is on a distinguished road
Hello did you study flow of nano-fluid over cylinder? you mean an external flow problem?
Originally Posted by Aarthy Meena View Post
Hello Everyone,
kbaker is offline   Reply With Quote
Old   November 1, 2015, 00:59
Aarthy Meena
Yes, I am studying external flow of nanofluids around an unconfined square cylinder at a Reynolds number range of 10 to 40. I am varying the particle volume fraction from 0 to 5%.
My problem is that with an increase in particle volume fraction, I observe a decrease in mean Nu and C_D at all Reynolds number. This is contradicting with the basic behavior of nanofluids and literature.
I am stuck with this and I am unable to proceed with my work. Kindly, Please help me solve this.
mixture model, multiphase flow, wrong nu and c_d
Problem accessing material properties in UDF for Multiphase Multispecies pmtgt Fluent Multiphase 3 January 17, 2021 07:11
Boundary Condition problem with multiphase flow daroz OpenFOAM Pre-Processing 0 August 13, 2013 11:09
Low pressure de Laval simulation convergence problem heksel8i FLUENT 3 July 22, 2013 10:28
SetFieldsDict file problem with 3D multiphase flow jeff_87 OpenFOAM Pre-Processing 11 May 3, 2013 06:20
multiphase mixing Problem with MRF model in MixSim Srinivas FLUENT 0 October 17, 2005 06:35
