November 1, 2016, 08:26 |
DPM Modeling problems
Utsav Jain
Rep Power: 11 |
Hello guys,
So I am doing a steady state combustion simulation with liquid and atomized fuel. This is how I am proceeding: 1. I run the non-reactive case to get a stable solution making sure that my mesh is correct or fine enough. 2. After I get a steady non-reactive contours, I switch on the combustion and then run iterations to get a steady contour for reactive scalars. 3. Once I get a steady and converged solution for reactive scalar, I switch on the DPM model and inject particles from the inlet surface. When I do this, the entire domain becomes unsteady and I never get a converged solution. By not getting converged solution I mean that the residuals keep oscillating (which maynot be a problem as they oscillate in my second step as well) but the mass flow at the exit also oscillates and doesn't come to a constant value. I am not able to understand the problem? As my flow is not getting converged, even after a large number of iterations with DPM modeling switch on, I don't get proper contours as a result of which the particle evaporation doesn't take place at the right place in the domain and some particles remain incomplete because of lack of evaporation. I am not sure if the mesh is the problem or any other thing. I will be thankful if anyone can help with the problem. There are a lot of details associated with the simulation so let me know and I will give you more details. For now I am running a steady state problem. Also I am not switching on the unsteady tracking of particle. I also wanted to know how my solution will be affected or what is the different between switch on the unsteady particle tracking and what I am doing? |
convergence, dpm, fluent, steady simulation |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
modeling counter current flow in DPM | Eloise.rhm | FLUENT | 0 | February 26, 2015 04:43 |
Short course: Modeling of Water Resources and Environmental Problems using OpenFOAM | liu | OpenFOAM Announcements from Other Sources | 0 | March 14, 2012 16:32 |
Aeroacoustic Problem (Modeling Flow-Induced Noise Problems Using FLUENT) | cici | Main CFD Forum | 0 | September 29, 2011 14:28 |
DPM problems | hendar_k | FLUENT | 2 | May 22, 2011 22:15 |
