Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
free surface diffusion VOF
Like Tree1Likes
  • 1 Post By silent2608
Old   January 30, 2016, 04:38
Default free surface diffusion VOF
Ema40 is on a distinguished road
Hello.
I am simulating an open channel flow with VOF.
The free surface is not well defined and the transition between water and air occurs through a large (not physical) transition.
There is a way to reduce this transition and to have a free surface better defined? I know that I can reduce the mesh size. Are there other methods?
Thank you
Ema40 is offline   Reply With Quote
Old   February 4, 2016, 10:49
silent2608 is on a distinguished road
Mesh size and interface reconstruction scheme are your only options as far as I know (compressive is ok, geo-reconstruct is very good but very slow)
silent2608 is offline   Reply With Quote
Old   February 5, 2016, 04:58
Thank you, but in Fluent only these schemes for VOF are available for the Volume fraction calculation:
- first order
-second order
- quick
-compressive
- modified hric
-bgm
What do you suggest to me?
Thank you!
Old   February 5, 2016, 05:17
mesh: for vof use mapped quad mesh in 2d (equally sized rectangles)
uniform mesh size or gradual cell jumps!!!! skewed mesh will result in utter destruction
to avoid instant crash through momentum divergence set VOF model to explicit, 1e-06 volume fraction cutoff, courant 0,25 in model window (defaults)
implicit scheme is faster but you need to know with which settings you get realistic results, so I will propose conservative settings
PISO
Green Gauss Node Based
Body Force Weighted
Compressive (geo reconstruct better but more computing cost)
Transient: first order implicit (vof explicit - only first order available)
timestep: variable and courant <= 1
explicit vof + compressive + bounded second order is almost as good (and faster) but you need to know about your flow (timestep) or you will face divergence problems and unphysical behaviour
getting physical / good results requires understanding of vof model, interface reconstruction etc. pp.
take these settings and adjust after reading more on the subject, proper setup is not trivial
Jehosh likes this.
Old   February 6, 2016, 04:22
Thank you very much!!
Regards
diffusion, free surface, open channel flow, two phases, vof
VOF Free Surface height varying along the wall mohibanwar FLUENT 0 June 10, 2015 03:24
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
VOF simulation free surface caused by gas inject rensb FLUENT 4 July 20, 2006 04:45
VOF free surface tracking LK FLUENT 2 May 20, 2006 12:20
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
