June 13, 2016, 08:11 |
Lee mass transfer mechanism
faraz
Rep Power: 10 |
Dear all
In my case . i want to use lee model for evaporation and condensation mass transfer but actually can not set the model. what is evaporation and condensation frequency? default is 0.1, should i change this ? what is the range of it? thanks for Guidance |
July 16, 2016, 15:24 |
Mohammad Bahreini
Rep Power: 13 |
Hi Faraz
I implemented lee mass transfer model in openFOAM cfd package. you can choose for frequency of 0.1 to 1000!!! first you should found you're experimental test case and then test for set frequency you can read my paper that used this mass transfer model. "Numerical simulation of bubble behavior in subcooled flow boiling under velocity and temperature gradient" |
July 28, 2016, 13:30 |
Przemek
Rep Power: 16 |
Hi mecman,
I also implemented the Lee model, however I get only evaporation but I don't see the condensation (in simple Stefan problem). Can you tell me what I am doing wrong? Here is my case and udf: http://www.cfd-online.com/Forums/flu...on-doesnt.html
best regards pblasiak |
September 7, 2016, 11:51 |
Rep Power: 11 |
what I do is also to use mixture model to simulate evaporation and condensation in a square channel, have you fixed you problem? we can do more communication.
thanks dong |
September 7, 2016, 13:23 |
#5 | |
Przemek
Rep Power: 16 |
Unfortunately I did not solve my problem. For now I do not know how to fix it.
September 20, 2016, 05:43 |
#6 | |
Przemek
Rep Power: 16 |
solution here http://www.cfd-online.com/Forums/flu...on-doesnt.html
July 20, 2020, 21:17 |
Arun raj.S
Rep Power: 14 |
Hello gaza, were you able to successfully simulate condensation?
mass transfer coefficient | ArturTU | FLUENT | 1 | October 27, 2015 10:04 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
About phase change heat and mass transfer | Michael | FLUENT | 2 | February 13, 2011 01:49 |
How to calculate Volumetric Mass transfer coefficient using CFX? | tuks_123 | CFX | 2 | July 22, 2010 01:15 |
Vof, udf and mass transfer panel | Jay | FLUENT | 1 | March 15, 2005 00:29 |
