Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Out of date mesh after scaling
Old   July 8, 2018, 13:58
Default Out of date mesh after scaling
Amiya
amiyaabhash is on a distinguished road
Hi everyone.i have created and meshed a geometry in hypermesh and imported it in fluent.i had created my geometry in mm. So I scaled it in ansys.After scaling it is saying out of date mesh.Any suggestions how to get it right?
amiyaabhash is offline   Reply With Quote
Old   July 8, 2018, 19:56
`e`
`e` is on a distinguished road
Is the mesh now the correct scale and are the simulations working? Fluent could just be warning that the imported mesh is different to the one you are using (because you scaled the coordinates).
`e` is offline   Reply With Quote
Old   July 11, 2018, 01:35
Amiya
actually in the graphics ,option for contours is not coming
[IMG][/IMG]
Old   July 12, 2018, 01:13
`e`
Are you able to plot the mesh? The contours and other plotting options are only available when there are values to plot (for example, after initialising or running the simulation). Alternatively, you could scale the coordinates in your geometry software, or use an intermediate process to scale from mm to m to avoid this problem altogether (assuming this scaling is the cause of the problem).
[swak4Foam] [OpenFOAM] [2.3.1] Install swak4Foam in Ubuntu 16.04.01 with errors ycui OpenFOAM Community Contributions 2 November 14, 2016 07:41
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
