Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Which Multiphase Model Should be selected in Fluent for my below described simulation
Old   September 28, 2017, 12:05
Default Which Multiphase Model Should be selected in Fluent for my below described simulation
Erick
oberstar is on a distinguished road
Disclaimer - this is my 2nd ever Ansys-Fluent simulation and I have not had any formal CFD training yet.
I am working on a simple ANSYS Fluent (16.2) multiphase flow simulation . The geometry is a larger straight tube with a smaller straight tube inside the larger one along the same axis with one end of each tube sharing the same plane.
I intend on having the the ring around the smaller tube defined as an inlet for one fluid type (Fluid 1) and the smaller tube an inlet for a 2nd fluid (Fluid 2) with the mixture coming out the far end. See attached model rendering.
I am at the point where I need to configure the Multiphase Model in Fluent and I am having difficulty identifying the correct model and parameters for the type of mixing model I hope to create. Fluid 1 will be a glycerol like fluid with a pulsatile flow up to 50cm/sec, and Fluid 2 will be a constant flow (or pulsatile flow) up to ~140 cm/sec of a homgeneous solution of specified concentration of an additive with a more syrup like viscosity. I am hoping to use the simulation to understand how Fluid 1 dilutes Fluid 2 farther down the pipe and how the net concentration varies over distance with the pulsatile mixing.
It appears from my searching I should use an Eulerian Multphase model based on page 8 of http://www.bakker.org/dartmouth06/engs150/14-multi.pdf and https://www.sharcnet.ca/Software/Flu...ug/node876.htm .
I can rule out enabling the boiling model and evaporation-condensation parameter options but I am unsure of whether to use Multi-Fluid VOF Model or Dense Discrete Phase Model in the Eulerian Parameters config window & If I do pick Multi-Fluid VOF how do I determine what to specify for the volume fraction cutoff and Courant Number?
Thanks in advance for any advice.
Erick
oberstar is offline   Reply With Quote
What is proper boundary condition to model Pump inlet in a multiphase simulation? shivasluzz CFX 3 June 26, 2017 19:15
Multiphase simulation of bubble rising Niru CFX 5 November 25, 2014 13:57
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
k and epsilon were hard to converge in multiphase model of Fluent Yanlong Li ANSYS 0 January 2, 2013 05:25
New to multiphase fluent simulation, any tutorials Camps FLUENT 0 September 9, 2006 11:41
