Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
VOF multiphase analysis of a micro-Nozzle
Old   April 7, 2021, 09:55
Default VOF multiphase analysis of a micro-Nozzle
Muhammad Haris
harris047 is on a distinguished road
Hello, I am working on two phase (helium and water) volume of fluid analysis of a micro-nozzle, to study the formation of jet and effects of boundary conditions on the jet.
I need help to verify whether the solution models and controls im using are right or wrong because the results im getting are wrong (according to experimental data).
General:
Pressure based
Axi-symmetric
Models:
Volume of fluid (implicit)
Implicit body forces checked
Interfacial anti diffusion Checked
Boundary conditions:
velocity inlets on body Helium and water inlet
Outlet = Outflow
Solution methods:
Pressure velocity coupling = coupled , coupled with volume fraction
Solution Controls:
flow courant number = 0.25
Vof Courant number = 0.25
Time step size = 10s
Number of time steps = 2000
Last edited by harris047; April 7, 2021 at 10:05. Reason: Insufficient information
harris047 is offline   Reply With Quote
Old   April 7, 2021, 19:17
Yasser Selima
Yasser is on a distinguished road
First comment is the time step .. this is too large. To estimate your time step, calculate dt = dx/U where dx is the minimum length scale and U is the maximum velocity in your domain. It is better even to go to less than half this value.
Second, Outflow boundary conditions is not recommended in two phase flow. You need to make it Outlet Pressure
Third, The results are function of the model as well as the mesh ... you might need to increase the mesh quality and/or refine your mesh
Yasser is offline   Reply With Quote
Multiphase analysis of Humidifier using ANSYS-CFX Suraj Marale CFX 3 July 28, 2016 11:01
Nozzle Analysis Akbar FLUENT 1 March 4, 2010 11:28
axisymmetric nozzle analysis Marcos CFX 3 October 8, 2008 07:23
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 01:45
Analysis of propeller with nozzle Ammu FLUENT 0 July 1, 2005 08:00
