December 19, 2017, 18:59 |
Calculating lift for a darrieus VAWT
muhamad elberens
Rep Power: 9 |
Hello everyone as i am simulating a vawt using fluent there is moment, lift and drag coefficient, the problem is the peak of the Cm curve of one blade happens at the peak of Cd curve it should be happens at the peak of Cl cause darrieus vawt is "lift driven", so i thought that fluent can not catch lift at hight angel or attack at azimuth nearly 90 degrees because of the large separation, so i need more refinement;
or that fluent calculating lift from the center of the moment "rotor rod" so i should use UDF to define the new center that lift should be calculated " center of blade ?! Thanks in advanced |
April 8, 2021, 22:08 |
alan
Rep Power: 9 |
Hi, I`m interested to know. Have you found the answer?
Role of Reference area for calculating drag and lift coefficients. | shashanktiwari619 | ANSYS | 0 | February 8, 2017 05:18 |
calculating lift and drag coefficients _ running in parallel | Mike_star | OpenFOAM Programming & Development | 1 | April 4, 2016 11:16 |
Vortex Lattice Method: Calculating lift using circulation from vortex ring elements | black&gold | Main CFD Forum | 11 | June 26, 2011 23:51 |
Reference Area for Calculating Lift and Drag Coefficient of 3D wing | mahbub03 | Main CFD Forum | 3 | May 19, 2011 00:21 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
