January 23, 2018, 04:11 |
backflow volume fraction in pressure outlet
a
in multiphase modeling, the backflow volume fraction should be defined at the pressure outlet, Is it right that the value being set as "1" means the second phase total reflux?
what about the value being set as "0.5"? What should we do if we want exit of one of species in outlet? |
March 5, 2018, 10:10 |
Cees Haringa
You should set it to what is the most realistic for your problem. If you have, say, a column with a gas-filled headspace, then backflow should be 100% gas, Just regard it as an additional inlet - in case the flow would be inward here, what would be flowing back in?
Generating water waves - backflow at the outlet | Luke92 | CFX | 1 | November 18, 2017 05:27 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Finding Volume fraction at outlet when it changes its phase. | praveen.jpk | Main CFD Forum | 1 | August 18, 2014 07:18 |
Backflow occuring at a pressure outlet? | Dave | FLUENT | 1 | August 12, 2004 17:39 |
