Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Coupling SST to FLUENT and data sharing
Old   November 12, 2019, 07:28
Default Coupling SST to FLUENT and data sharing
Bharath Thumula
Bharaththumula92 is on a distinguished road
"I have a case in which i solved a thermal case in ansys steady state thermal. Now i have the temperature plot on a solid surface. I want to use this temperature as a wall temperature to adjacent fluid in FLUENT. Can we do coupling from SST to FLUENT. I had seen coupling from FLUENT to SST but not vice-versa. Please provide any materials to do it ?
Bharaththumula92 is offline   Reply With Quote
Old   November 12, 2019, 18:13
Joshua
jbo214 is on a distinguished road
https://www.scribd.com/document/3536...-Tutorials-181
Page 41
You can use the system coupling toolbox to pass data from steady state thermal solutions to Fluent. Read through the user guide included with your install of Ansys.
jbo214 is offline   Reply With Quote
skinnyfluid, stumpy
Coupling SST to FLUENT and data sharing. Bharaththumula92 Fluent Multiphase 0 November 4, 2019 03:17
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
