Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
An issue on CFD/PBM coupled simulation in fluent?
Old   February 11, 2020, 08:10
Default An issue on CFD/PBM coupled simulation in fluent?
Amir.11 is on a distinguished road
Hi all,
I’m working on a CFD/PBM problem with only constant particle growth through a laminar flow reactor.
As far as I know, when particle growth is constant and occurs alone (no nucleation, no agglomeration and no breakage), the number of particles at outlet has to be exactly the same as inlet.
However, simulations on laminar flow reactor shows an increase in particle number withn the reactor i.e. there is somehow creation of particle in the reactor specially in near-wall zones.
The number of particles at inlet is N=1.91e14 and at outlet it increases to N=2.55e14.
I tested this issue on an ideal plug flow reactor where there was no velocity profile and the particle number at inlet and outlet were exactly the same.
What I am trying to say is that, I think, the problem is not related to PBM algorithm and it arises when PBM is coupled with CFD.
So the question is what is the mechanism in fluent which makes this problem to occur?
My case study is:
2D-Axi (L=0.1(m) , D=0.006(m)), laminar, Eulerian mixture model, PBM model (Standard Method of Moments).
Boundary conditions: axis, velocity inlet, pressure outlet
Solution Method: Coupled
Spatial Discretization: moment: 2nd order upwind, volume fraction: Quick, Momentum: 2nd order upwind and pressure: Presto.
Any comment would be highly appreciated.
Amir.11 is offline   Reply With Quote
Old   February 11, 2020, 09:14
Default PBM setup
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
What are the PBM settings for your case? How many moments are you considering?
I wouldn't expect any effect of coupling on 0th moment.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
cfd, method of moment, multiphase modelling, pbm, population balance model
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle FelixJJ FLUENT 2 October 20, 2021 02:39
How to run multiple cycle pulsetile flow simulation in Ansys fluent using UDF code? Md Al Amin Sheikh Fluent UDF and Scheme Programming 4 January 28, 2020 11:55
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
Simulation on fluent 14 NAD FLUENT 0 September 11, 2013 02:05
LSR (Land speed record) car simulation on FLUENT Maxime31850 FLUENT 2 May 1, 2013 11:15
