Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Spray drying of milk
Old   April 14, 2020, 09:55
Default Spray drying of milk
Telangana
subash Reddy Kolan is on a distinguished road
Hello ,
Iam working on spray drying of milk in fluent. Iam new to fluent. Can you suggest me how to add material (milk droplets ) in Ansys.
Thanking you
Subash
subash Reddy Kolan is offline   Reply With Quote
Old   April 14, 2020, 10:28
Default Droplets
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
For spray drying, you need to use Discrete Phase Model. Once enabled, you need to create injection wherein you can specify the flow rate, location, temperature, diameter, etc. for milk droplets. There is a spray dryer tutorial available on Ansys site.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 16, 2020, 10:02
Default Properties
vinerm's Avatar
Vinerm
Once you enable DPM, the material chosen for the injection will appear under Materials. You can change the properties then. For evaporation and drying, you will have to enable different types of particles. I'd suggest you to do it one step at a time. First track all milk droplets without any evaporation. Learn a little more about how to setup and post-process. Then use droplet type available within DPM Injections to model evaporation.
I'd recommend using Forum instead of PM so that others could learn as well.
Regards,
Vinerm
Old   April 24, 2020, 18:41
Telangana
Thank you Vinerm.
I have done as you said.
Droplet type ensures complete drying of droplet.
But I want only volatile part of droplet has to be evaporated, while solid part should come out as particle.
Old   April 28, 2020, 15:37
Default Volatile Fraction
vinerm's Avatar
Vinerm
You need to specify the volatile fraction in the Materials for the droplet material. Default value might be 1.0 Change it to the volatile fraction and only the volatile fraction will evaporate. Solid will remain.
Regards,
Vinerm
Old   June 3, 2020, 19:14
Raminium is on a distinguished road
Thanks for the explanations. Could you please advise where the tutorial can be found in the Ansys website?
Cheers,
Raminium is offline   Reply With Quote
Old   June 4, 2020, 04:32
Default Spray Drying
vinerm's Avatar
Vinerm
A relevant tutorial is available at Customer Portal.
https://support.ansys.com/AnsysCusto...FLUENT/2046025
Regards,
Vinerm
Discrete Phase Modelling for spray drying of milk Hailish Fluent UDF and Scheme Programming 0 November 5, 2018 09:28
DPM approach for spray drying umairjamil FLUENT 0 July 20, 2016 04:56
single phase spray drying zdunol Main CFD Forum 1 March 14, 2014 10:10
counter current spray drying sachin_pathak FLUENT 1 April 8, 2012 05:56
spray drying sachin_pathak FLUENT 0 November 26, 2011 11:06
