June 16, 2020, 00:57 |
Is there a way to rotate the patched region?
Shuyan
Rep Power: 6 |
I am doing a simulation with water and vapor involved. I am looking for advice on how to rotate the patched region (image attached), or to create another region that is not defined by x,y rectangular coordinates. Previously I have no issues patching the water region into my simulation as it was vertically upright. Now, with the addition of an inclination angle, I am lost. Sincere apologies if this was a simple question! Shu Yan |
June 16, 2020, 11:35 |
Patching
You can't rotate a patch but you can apply a rotated patch. It depends on the procedure you are using to apply patch. If you use region to mark the cells, then use box with coordinates representing the corners of the rotated rectangle.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Can I use fvOptions to couple a solid region and a fluid region? | titanchao | OpenFOAM Running, Solving & CFD | 4 | January 14, 2022 07:55 |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 15:53 |
HeatSource BC to the whole region in chtMultiRegionHeater | xsa | OpenFOAM Running, Solving & CFD | 3 | November 7, 2016 05:07 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
