Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Multi Phase_ Multi Pressure Cell Zone_
Old   October 27, 2020, 19:34
Default Multi Phase_ Multi Pressure Cell Zone_
Mohammad Jamali
Mohammad_Jamali is on a distinguished road
Hi Dear Engineers .
i have a Model For Trace Methane Leak In Gas station -
at the Present I have Some Question :
1: after selecting Multiphase Model and Define Cell Zone As Pic - i need To Define cell Different Properties after Initialize , in Patch Window I want Define coefficients such Volume Fraction and Cell Pressure but There aren't Some Variables Such Pressure which I need , I try to Define Field Function But It does not work Properly and Effect on Volume Friction Variable , Now How I Could To define These Coefficients?
2:Can I define Material Properties by Use Of Piece Wise Liner or Polynomial Function that Set By Pressure ( Not Temperature ) or need to UDF ?
Thanks so much for the helps from friends
Mohammad_Jamali is offline   Reply With Quote
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 11:25
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 12:41
Change cell zone index/thread during simulation neilduffy1024 FLUENT 0 January 17, 2011 09:40
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
