How to define two different phases with different species |
February 9, 2021, 17:07 |
OH
Rep Power: 5 |
Hello all,
I am trying to model CO2 being dissolved in a bubble column filled with water. For mass transfer definitions, I need to define two phases: for instance, liquid and gas, where the liquid phase includes h2o (l) and some other species, and the gaseous phase includes CO2 and air. Fluent only allows me to define material type as "solid", "fluid' or "mixture". I define one "mixture template" in which I add CO2, Air, and H2O (l), but I cannot add another "mixture template" in which I could define similar or different species. I define a dummy phase for CO2, but inside this dummy phase I cannot define a species under "Multiphase model -> Phase Interaction -> Mass -> Mass transfer -> "from phase" and 'species" to 'dummy phase" and "species". Can anyone please help me with that? I want to do this to instruct Fluent to have mass transfer from CO2 in one phase to CO2 in another phase (dissolving)? Thank you! |
February 26, 2021, 04:31 |
Hang
hello, I have the same problem with you. Have you solved it? Can I ask you for some instructions?
February 28, 2021, 10:51 |
OH
Rep Power: 5 |
Hi air,
Yes. For creating a new mixture, when fluent ask if you want to overwrite say no. In this way, you can create a new mixture. |
bubble column, mass transfer, multiphase flow |
Hydrogen storage by metal hydride | longbk | FLUENT | 12 | August 1, 2023 20:13 |
how to define diffusion coefficients for every species in the system? | Weiqiang Liu | FLUENT | 7 | June 23, 2021 10:03 |
udf for source term in UDS equation | dkjknobel | Fluent UDF and Scheme Programming | 12 | August 19, 2019 07:57 |
difference beetween phases and species | Emanuele De Bonis | FLUENT | 1 | February 5, 2007 12:35 |
How to define 2 phases with mixture? | Pbh | FLUENT | 1 | June 7, 2006 02:50 |
